I'm on kJams version 1.0.1b71.
Using Safari on an iMac, I can see the server in the Bonjour list. But when I try connecting to it, it says can't connect.
Using wtkJams, it can't connect either.
I have firewall turned off.
Can't connect to server
Re: Can't connect to server
is the server turned on?
is your iPad & mac on same network?
does your router prevent peering?
Yes, it is turned on, and everything is on the same network. All the same networking equipment that worked before I upgraded.
If I start up kJams and quickly try connecting with Safari it can connect. But after sitting for a minute or so, I can no longer connect.
try rebooting your router? in fact, reboot everything.
