re: Duplicate File Name
Debassman
Post by Debassman »
Dave,
Upon starting the program, I am getting an error "Duplicate File Name" and then it says "Error renaming Song" It has created many duplicate song names of one particular song in my library. What is causing this and what Can I do to remedy it?
Re: re: Duplicate File Name
i've never heard of that, please write me directly. kjams doesn't make duplicates of songs, that i know of.
Debassman
Post by Debassman »
Ok, will write you so we can setup a time for you to take a look at it for me.
OK. FYI, last night i discovered that kJams wasn't clearing the temp folder correctly (if at all) and that has been fixed. it's possible that would cause it to try to re-add a song bought from Karaoke Locker after every startup. (windows only).
