Background filler music
robtromp
Post by robtromp »
Why not go for full background music support? Nothing worse than dead space because a singer isn't ready, the rotation hasn't built yet, or the KJ needs to take a longer potty break.
Re: Please add Shuffle
Also, my script for kJams Pro and Dave's for kJams 2 already handles background filler music
Moving this to a new thread makes this statement come entirely out of context, so might as well kill it! :)
Last edited by DeusExMachina on Wed Feb 26, 2014 12:13 pm, edited 1 time in total.
Re: Background filler music
While it's true that kJams 2 provides the ability to crossfade into iTunes, kJams does really need to handle this itself, and it is in the plans to do so.
thekaraokeprincess
Post by thekaraokeprincess »
I realize this is a super old thread, but I think this is a really great idea. A system I used to use (PCDJ) had a separate playlist for background music within the program, and it was pretty awesome. I'm new to Kjams, so I'm still learning, but in my tiny bit of experience so far, it seems the songs don't really fade in/out very smoothly when set to automatically crossfade to my iTunes. Maybe there's a setting to tweak this that I have not yet discovered. Dave has done such a fantastic job of providing endless info so it's probably documented somewhere. :)
can you define "smoothly" ? it seems smooth to me?
It should already be very smooth. Perhaps you have a system processing issue.
If you need to, however, you can edit the script, changing the values for fadeDelay to a smaller value and fadeSteps to a higher value. This will make the fade even more gradual. But again, not sure that that should be necessary. I can check the code again, but it works just fine on my end, and every machine I have tested it on.
:shock:
